PM Warbaby. Probably depends on what you get. If you got the Escort SOLO no plug-in required since it runs on batteries. Others would require 12VAC (I think), so you could run a lead direct to the battery or add a DC plug in the trunk and use an adaptor if the detector is equipped. You could also run a lead to the fuse panel. Too many things in my head and I'm not a real electrical guy, so I hope what I said makes sense.
