Mounting Titainium Rear Brake Rotor
Did you use the Gafler (green) 111 G 1532 pads and remove the piece of spring steel from the caliper to allow the pads to "rattle about" a bit?
i got the rotor from yoydyne, and it came with the green pads and i did remove the spring steel pieces. i am not a heavy rear breaker. the rotor is not worn just warped.
200 miles?
I can see this rotor warping if you are a "rear braker". This TI. rotor will not hold up under heavy braking, it was never intended to do so, and Fred from Yoyodyne will tell you just that.
