mre speed cheap mod.
Remove the reflectors, warning labels, tools, manual, and tank prop.
Then lose weight :laugh:
He's new guys. so I hope he knows we're all kidding.
2 up rear sproket would give you more thrills IMO.
(and loose weight) :laugh:
The F.O.G that you see about really means Fat Old Guys, so we know what we are talking about. :whistle:
:rofl:
My '06 seems to go a little faster when I twist the right hand grip, not so much with the left one. :laugh:
Are you talking faster as in top end or quicker? +2 tooth sprocket on the rear will make it quicker but lose some top end. Weight loss (bike and/or you) will improve both.
Ok ok... so here's the list so far...
1) 42tooth sprocket on the rear (quicker accel)
2) Exhaust (A must, the stockers are real restrictive) -Most expensive
3) Power Commander -2nd Most expensive
4) R1 Throttle tube (Stockers are slow gradual)
sounds good.... although
for more acceleration you need a bigger rear sprocket or a smaller front one or both. smaller rear sprocket like a 42tooth would raise your top speed (if you have the hp) and lower your rpm at highway speed.
stock 08 is 18/43btw
