Umm, you do know how an internal combustion engine works right?they don't have "rods". chain driven cam.
Ahhh. He's excused then.Don't blame him, he's thinking pushrods. Like Harley's speak.
Entirely possible. If nothing else I'd get a balanced kit from APE. Crank, rods, bearings, gaskets. Check the cylinder wall, the thrust area tends to get hurt as the bearing fails and scores the cylinder wall and piston. If that's good, screw it together and call it good!I'd pull the caps off the bottom end & check the crank, it might just be ok, new bearings & a little emory cloth & she's on the road again. Or could be effed up. Hell, with your luck I'd think bearings only.
Wow, did you get a title with it?
So I was seeing this gal with a totally tricked out Busa. She was telling that her trans was slipping and I had a friend with a Busa which I thought he had wrecked. I happened into him one day asked him if he still had it and told him the story. I thought I would surprise her with the trans from it, so I asked him what he wanted for it. 500 he said. I asked "For the trans"? nope whole bike it has engine problems and I had thought about shipping it out of state to a relative. Sight unseen I said SOLD! I couldn't believe it when I saw it...
https://www.hayabusa.org/forum/images/styles/Hayabusa/attach/jpg.gif
Of course these are after I aired the tires and washed it and installed a new battery and oil change.
Thanks everyone!! I think I found the problem... Now I need to figure out where to send the crank to get fixed?? I'm actually still tearing the bottom end apart, you can see the discolored rod end and I think the bearing is completely gone.
I think we was set up with this one. Looks like a lot of work to take place in this timeframe,
First post 02-09-2012 03:15 AM
Second post 02-09-2012 03:03 PM
Well, "douche" is kind of a strong word to use in this context, especially when it was meant as a joke. (note the ROFL character)Ajay, not sure why someone w as many posts as you would be a douche and flame a new member but whatever... Maybe you're one of those guys that thinks black helicopters are following you and listening to all of your conversations.
If you'd like to apologize find me a cheap pcIII for this thing and I'll forgive.
