turbojonn
It's been maybe 6 months since I posted much here. So here's an update. My bike should be done in a month or so. I took my bike to Bert. He's making it into a whoop-ass mean machine (at least as much as humanly possible on my cheap ass budget). The old rajay is gone, as is all of the Mr Turbo stuff. Now it has a dual ball bearing mother bitches of a turbo that will, when I can afford to upgrade from s2000 injectors, support over 500 hp. The way it will be set up it should be good for 320-340 hp. He's putting on an air to water intercooler (bye- bye race gas), new plenum, spider pipe, wastegate, all the stuff. It's even going to have a water cooled bearing housing. I can't imagine what he could do if I had a decent amount of $ to spend. He also switched out the stock fan with a Muzzy fan, fixed the funky wiring, put in big boy clutch springs, new pads and rear rotor, and lots of other stuff. He even took it upon himself to dig into his box of Suzuki tid-bits and switch out all the little mismatched nuts and bolts that had found their way onto the bike through all of it's prior projects. Thanks Bert--you da' man!
