120w bulb=melted connector/wirings/headlight
I agree, a 120w bulb would be extremely problematic (over time) using stock connectors/wiring.
Fortunately, full must know this, and that's why he did
not install a "120-watt" H9, or the "110-watt" H7. Look closely, and you'll see these figures are the PIAA marketing hype; the actual power consumption is the typical 55-watt H7, and 65-watt H9 bulbs.
The reason they appear "brighter" is the way that PIAA designs these blue coated bulbs, which removes a certain frequency from the light emitted. In this case, the yellow-orange-red end of the spectrum is filtered, letting the white to blue color temps through. To get more light out of a filtered bulb, they have to pump a lot more light through the filter (this is known as being "over-driven": heating the filaments hotter than normal). This typically results in an abbreviated lifespan (compared to non-overdriven bulbs), particularly in motorcycle applications, as full will discover in the coming months.
Osram Silverstars and the Philips (Germany) X-Treme Power H7's are not the same thing, they are not over-driven, and not blue filtered. They are very efficient, and put out near the maximum lumen level of a halogen bulb can
physically produce. They look whiter than standard, but not as white as the PIAA bulbs, because they get their color purely from output level, not from filtering.
If I were going to stay with halogen technology (which I am not), there is only one brand of H7s I would consider using:
Philips X-Treme Power H7 from powerbulbs.com
Mind you, the above bulbs are not cheap; the Good $hit never is.....
<div class="iF-Passage"><div class="QUOTEHEAD">Quote:[/Quote]<div class="QUOTE clearfix"><span class="quoteBegin"> </span>
xenon/hid is today... i´ll go for 55W xenon/hid[/quote]
This statement may suggest a mis-understanding of the nature of true HID versus these marketing-speak "xenon/hid" bulbs. True H7-based HID systems (utilizing a DS2 bulb) typically consume 35-watts (once fully up to temp). There is no halogen bulb that is a true HID, regardless of what is printed on the package.
A true HID system is the only way to fly if the rider is seriously interested in being able to see far down the road at night, at speed. Halogen technology - even these over-driven bulbs - don't hold a candle to true HID. I have been using these HID conversion systems in all my LD Rally bikes for almost 10 years now, both in H4 and H7 applications. When done right, these are a staggering improvement over anything a halogen bulb can produce. The biggest single factor in a successful HID deployment is that the DS2 bulb
MUST achieve the *exact*, *same* focal point as the stock setup. If the arcing "filament" in a HID bulb is not placed exactly so, the results are a horrible amount of "scatter and glare" that gives HID conversion kits the bad rap that they have among the NHTSA nannies, and it has the potential to eventfully result in adverse legislation.
