Ok so I see yesterday that there is oil leaking from whatever the cover is right beside the shifter lever (stator cover?). So I get a socket and rachet tighten up the bolts there on the bottom half of it. Some I got about a 1/4 turn maybe a little more on 1 or 2 of em but i see today that its still leaking a little. Should I tighten em up a little more (I know the heads can be snapped off so, I dont wanna crank on em too much), or is there a gasket there that might be bad that I should replace. Thanks in advance for any info!!!!
