Need Help ASAP!!!
The marble goes in the hose which goes in the middle of the airbox correct?
I took it out and got it hot then pulled the tank and air box and somehow oil is getting into my throttle bodies.
You shouldn't have a marble in any hose if you took your pair system off and used block off plates unless you cut the tube down and are using the marble to cap the line off.
When you removed the pair valve system, there should have been 2 hoses a small one to the front of the throttle body and a large one that goes to the air box. The large one SHOULD have had the marble in it before you took the pair valve system off. Personally I just went to autozone and bought a cap/plug assorted kit for $4 and capped both areas(small one on the throttle bodies and the large one on the airbox).
ut oh... you kidding right??? the marble goes in the "right outside" hose .. the middle hose is the crank case breather hose..
Yikes!
well if he was not so secretive about "where he lives" someone could probably swing by and take a peek...
you plugged the wrong line and now the crankcase is blowing oil out of every point it can find to release the crankcase pressure.
In the above pics there is a tube that goes from the lower engine case to the middle rear part of the airbox, make sure this is plugged in, also make sure the other port (right lower part of airbox) is plugged off then make sure the small plug on the right throttle body is plugged.
This shoud take care of your problems unless of course you blew out the valve cover gasket from having the crankcase vent plugged off.
Hope all of that made sense.
Okay so I'm an idiot. I plugged the wrong hose. I guess thats what I get for assuming things huh? I live in southern Indiana by the way.
Well get the marble out of there of course... hopefully crankcase pressures did not blow any seals out permanently... you are going to need to watch it closely just in case.. a can or two of brake cleaner should get rid of all the oil mess..
Then run it and make sure you do not have any oil leaks... (it could take a few miles to get rid of any reside even after cleaning)
Seriously thought thanks a lot for the help. I'll fix this ASAP! You all are life savers. What a great group of people!
Pressure, and a marble....................PING-PING-PING !!!! That's why I'm afraid to mess with my own bike.........I could see the thread now....................Kennym4 accidently shot himself in the head performing "the marble mod", our prayers go out to his family !!
Is it fixed ??
Don't feel bad I am not a Mech either!
But I was smart enough to move from Indiana!
Is it fixed ??
O MAN Lord rest his soul
Oh gosh frisbee you don't have to rub it in! It's not so bad here...if you like nothing to do besides drinking and driving in the country. Tis why I bought my bike.
