Need help removing Cluster
especially if you have a kit that requires some sealing up of the low beam like the DDM kits do.
What do you have to seal and what sealant did you use? From other threads, I got the impression that you pretty much just replaced the bulbs and then installed the ballasts between the stock wiring and the bulb.
:hmmm:
:hmmm:
I used electrical tape, its really sealed good on its own, lucky for me the high beam was good and low with the cover just a bit tape and its good. The only problem is I was so excided to put everything back together that I forgot to secure the wires.:whistle:
