I have 7.5 and still have no luck.(semi @ Dec. 10 2006,12:05) i have a copy of Roxio Easy Media Creator 7 i can loan to you if you want to download it on your computer and see if it will read your DVD then
+1(GSXTacy @ Dec. 10 2006,12:03) You might want to go to the roxio site and update any drivers. I had to do that with my sony DVD burner.
Yes, Data DVD's.(300Busa @ Dec. 10 2006,12:05) did you burn the pics as a "data" cd when you did it?
wal-mart does this also however it was a CD-ROM so not sure about DVD media.(monster @ Dec. 10 2006,10:05)+1(GSXTacy @ Dec. 10 2006,12:03) You might want to go to the roxio site and update any drivers. I had to do that with my sony DVD burner.
This might be stupid but you might try bringing the discs to a Ritz store - they might be able to open them with their equiptment and make prints on the spot.
How?(300Busa @ Dec. 10 2006,12:06) try to email me one of the pics if you can rgeneral012000@yahoo.com
see if it works on mine.
go into your email and compose a new email and attach the file. Click "browse" and then "my computer" then your cd drive. Then click the file and send the email. If that doesn't work, I dunno.(Pipefighter248 @ Dec. 10 2006,11:34)How?(300Busa @ Dec. 10 2006,12:06) try to email me one of the pics if you can rgeneral012000@yahoo.com
I can't acces the DVD's enough to save.
Tried with no luck, just froze up.(300Busa @ Dec. 10 2006,12:36)go into your email and compose a new email and attach the file. Click "browse" and then "my computer" then your cd drive. Then click the file and send the email. If that doesn't work, I dunno.(Pipefighter248 @ Dec. 10 2006,11:34)How?(300Busa @ Dec. 10 2006,12:06) try to email me one of the pics if you can rgeneral012000@yahoo.com
Will try to flash drive.(trip @ Dec. 10 2006,13:40) How much memory is in the new PC?
Usually, when I get that type of responce from a cd/dvd drive, it's either
1) The drive can't read it - hardware issue = Update/Flash Bios in cd rom drive.
2) PC doesn't have enough memory - Roxio is a memory intensive application and may choke a PC without enough Memory.
3)Bad write - There are programs out there to read/restore a bad disk if it is salvageable. If Roxio saved everything in it's own format, it may be more difficult.
I don't always print my pics, but I do check all backups immediately after making them to make sure they took. Too many bad burns make coasters of backup cd's.
In the future, it's bet to copy directly to a cd like you would a hard drive. That way you can access the files individually instead of having to use a particular software. IE, Norton Ghost will back up your files, but you'll have to have Ghost installed to see what files are in the compressed image.
I would try ...
make another cd using that backup program to see what kind of format it uses. I doubt that Walmart or any other place will have software that will read a file created for and from Roxio. There may be recovery appz that will read that format.
Make sure you've flashed the bios in the DVD drive to the latest firmware version - much better chance the media will be read correctly. Even new hardware doesn't have the latest updates.
Make sure you have at least 512 MB of memory. In a new PC it should but I have a pc with 512 that craps out often while burning/reading media for that reason.
If it is a bad disk/burn... you looking for "Bad Copy Pro"
find it here...
http://www.jufsoft.com/badcopy/
Good luck!
...., trip
Tried to do coping, but no luck.(BiG-T @ Dec. 10 2006,13:47) Anyone close to your residential area w/ a computer that you can test the DVD with?
To retrieve the files you shouldn't need to have roxio installed on the destination PC so any PC other than yours should do.
I'd hate to think the DVD has bad sectors so if you have a blank DVD try to burn a copy of the original.
I don't recall (from the posts above) if you copied the contents of the disc to the PC first. If not, try that and then attempt to retrieve the files opposed to retrieving directly from the disc.
No Way... those guy's are dangerous!(Pipefighter248 @ Dec. 10 2006,03:05) I haven't given up yet, but do you all think the geek squad that works with computers could get this even if the dvd has bad sectors?
Just hate to see how much they would charge, but hopefully if they didn't fix it, they wouldn't charge anything.
Leaving to go to dad's, I'll keep you all updated.
I've used them with great (and costly) success.(Pipefighter248 @ Dec. 10 2006,14:05) I haven't given up yet, but do you all think the geek squad that works with computers could get this even if the dvd has bad sectors?
(Pipefighter248 @ Dec. 10 2006,15:39) UPDATE:
Just wanted to let everyone know that I got most of the stuff back.
I got all the family pics, baby pics, and bike pics back.
Only thing I lost are a few programs that can be downloaded again and 58 out of 138 bike videos.
Dad kept the discs and will be trying to recover the other videos, but if it doesn't work, then I'll live.
But main thing is that I got all the pics back.![]()
Will send a donation shortly to the board for all members that posted in this thread.
Thank you all.
Nathan
