need help
1127 TO 1299
Last night i installed my scorpiop alarm.
I just could find where to plug the 2 gray wire on the suzuki harness. They are supposed to be connected to the left/right turn signals.
But where to you actually make the connection?
BTW, very easy to install besides those 2 gray wires.
I believe you have to splice into those wires if you're not running the stock set-up. Otherwise I believe its a plug n play operation; Been awhile since I did this.......
Help from the board
<!--EDIT|ks-waterbug
Reason for Edit: None given...|1085063850 -->
You need to use the connectors supplied to splice into the turn signal wires IF you want the turn signals to flash (which isn't mandatory). The connectors will turn into a female connector once crimped together allowing for the male end to mate up with it.
haywood
i think i got it
this is what they are for those redish connector
when you close then around the wire you can see an slot where the grey wire can connect.
Thanks
