Sorry I didn't get back to you earlier.So what happen MC did you ever get it to work in the HI-Beam socket properly like the low beam ?
When I first installed the system I just sort of slapped them in with some electrical tape and they didn't fit well, and that was when I made that posts. That's kind of how I approach new projects when I'm jazzed up -- I installed my first car CD player in the dark in my driveway the same night I got back from Best Buy (only blew one fuse).
Anyway, some weeks after my first crack at the HID installed, after the steering damper had smacked into one of the ballasts a few times, I took the cowl off completely and really did it right. The ballasts are now really mounted as I've said they are -- with doubled-up wire ties in parallel and quite far forward and well clear of the damper.
The advantage of this kind of kit is that it is plug-n-play and although it's a little tight it will work and you'll get both beams upgraded. I'm sure there are several vendors who provide this kind of kit -- I think the only thing that makes these a little special is actually the lower temperature which makes for whiter light.
I'm sure that can be had elsewhere also, however.
