NEED TO DROP ENGINE SPUN ROD
are you sure you want to do this job, its very involved and finding the tools really is the easy bit :super:
You wont need a spanner wrench to pull the busa motor out. Regular tools and youll be fine. I think I used a flat head screw driver, and a hammer.
Go buy a cheap impact socket that is the same diameter as the the nut you want to remove. Next mark it with a marker where the pins need to be, and remove the materail around the pins with a hand grinder.
cost ya five bucks and works great
