CR08BUSA
I just bought a 2008 Hayabusa with 11,000 miles on her and within 200 miles the clutch completely went out on me and the oil light came on. I checkled the oil level and it was fine but I went ahead and changed it anyways. I replaced the clutch with an OEM clutch kit today and now it will ride and shift through all the gears but, the oil light still comes on about 10 sec. after start up and starts flashing in about 5 sec. intervals. When I rose it around the block it stays on. When the clutch went out it completely "shelled" and left a ton of metal shaving that I cleaned out as best I could but, I didn't drop the oil pan. So, I'm not sure if the oil pick up tube is clogged with shavings or the oil pressure sending unit is out or the oil pump went out when the clutches went??? My question is I suppose is there a way to check the oil pressure without having to install an oil pressure gauge? Also, when the bike is running and you lean it up to look through a them oil sight glass and rev the engine the oil does go upwards for the most part if that makes any sense? Sorry for the long post but, I'm a little frustrated about this situation and don't have much money at the moment, been laid off for 5 months, oil field work hasn't been good lately. So, any advise or pointers would be greatly appreciated even if I have to put the bike up in storage until I can get back to work and get her fixed. Thanks again in advance!
