first time rebuild
So i got my hands on a compression tester, i found 170-175 in cylinder 1,2, and 4...150 in cylinder 3. from what Ive read, that seems to be my issue. hears to hoping its just the gasketYou’d have to have a pint of condensation for oil to turn that color. Are you changing filters too? They catch a lot of stuff and in this case I’d use 2-3 oil filters to catch and clean the impurities in the crankcase. Why did the oil light come on? ‘Oil’ too thin? It didn’t come on the first time when most of the water mix was present.
However, a head gasket may be blown or the new head has a crack or the block may be cracked. Could be the wrong head gasket? I’ve never taken an engine into a shop for a new head so I don’t know what your instructions to them were. A compression test or a leak down test should be next. Good luck.
