DaySleeper
Just got my '07 running again after it had a dead cylinder. The bike only has 1200 miles but number one was dead as a doornail. My buddy and I pulled the plugs and they looked good but awfully lean. The first owner put pipes on it and didn't do anything to tune it after that. Unfortunately for us, I apparently put the old plugs back in the same holes on accident and the problem stayed with the same cylinder! So we started pulling and swapping injectors, pulled the pump out and checked the pressure, swapped the injector harness, swapped coils, etc. After much wailing and gnashing of teeth, I swapped the plugs again thinking surely the number one plug couldn't have gone back in the same hole? What are the odds? 1 in 4 actually, lol! The problem followed the bad plug into number two!
I put in new NGK cr9e's I bought from Autozone and put a tuner in the injector harness and presto, it runs awesome now. The plug was lean fouled.
I also deleted that silly flapper door and actuator in the airbox since it was sitting there mocking me.
I guess the moral to my story is, always change the plugs first.
Seth
Seth
