nitrous question
If you spray often the wear and tear factor is increased...I would oil is cheaper then other parts.........also bump up your oil pressure with a better oil pressure regulator they do work.
should you change your oil more often when you use nitrous does it thin the oil
That is something associated with Nitro Methane instead of Nitrous oxide. While it will not thin down the oil, running nitrous is a bit harder on the engine and oil. Engine that are ran harder or in racing applications could use a bit more frequent oil changes than the normally OEM recommended intervals to stay on the safe side.
+1 up on that
