Shifting is back to normal. Smooth as can be(for a busa).![]()
That is great to hear.
Instead of starting a new thread for my question I will post it up here. I have done alot of searching but have not found any real facts about it.
So, how long can synthetic oil sit in a crankcase before it loses its properties and becomes acidic? Im sure there are variables to this?
Here is my situation: I got injured (not bike related) and only rode my 2007 Busa 2,000 miles in 24 months time. So I have 2,000 miles and 24 months on Mobile 1 4t synthetic and a OEM filter. Will the oil still lubricate well enough and hold its anti corrosion properties after sitting that long of time? I usually change my oil out at the start of every riding season. And my instinct is to just change it out, why risk it right. But the oil isnt cheap, (cheaper than a engine or tranny rebuild though) and the oil in the crankcase looks good. I did run the bike last week for the seccond time this summer on the old oil and the bike ran and sounded fine. I am still healing so I wont be riding much more this season, maybee a couple days, few hundred miles, and I wont be riding it hard. Basically I am looking for anyone who has their own experiance, input, or info on the facts about how long synthetic oil can sit. I have new oil and filter ready to go in but I thought I would ask this first out of curiosity.
BTW. My bike sits in a insulated attached garage and temps here are not too drastic during winter so condensation in crankcase shouldnt be an issue. Bike was started every three months or so since sitting. Bike has 5,500 total miles.
One other thing. A properly maintained chain also helps with shifting.
I change my synthetic at 2000 miles!
Yes maybe synthetic oil doesnt break down as quick as non synthetics do.
All bikes breath air and in the air you have debri. I dont care how great your air filter is
or your oil filter debri gets into the engine and mixes with the oil. Also the clutch fibers will
also get in with the oil. Debri, clutch fiber dust will create engine resistance and enternal wear which acts
like sand paper putting small miscroscopic grooves on the enternal engine parts..
Even more so since our bikes have ram air tubes sucking air we will suck in more road debri
then a car or motorcycle with out ram air ducts.
Debri in your oil is what causes engine wear.
So with all that being said, I will change my synthetic oil at 2000 miles with fresh CLEAN gold colored oil nowing that I drained out the debri and clutch fiber particles....
Now I'm not advocating this by any means, but a guy on the bobstheoilguy.com forums had his conventional oil analzed for kicks that had been is his bike for 16 years and somewhere under a 1000 miles or so if I remember right, and Blackstone labs said the oil was fine. They did say they found some possible evidence of slight acidic corrosion, but nothing engine killing. I don't ride my bikes near as much as I should, and have left low mileage Mobil 4T full syn racing motorcycle oil in them for several years with no worries, condensation, shifting issues, noise or anything else.That is great to hear.
If you are getting dirt from the intake into your oil, you've got bigger issues than oil change intervals..![]()
You don't want to know but a whole lot further than 3600 miles. And on Mobil 1 Racing 4T. Never had that issue. Would be worth it to see how it does in another 4000 miles.
Are you saying the air that comes into the engines intake is pure with 0% particals or that the air filters stops this 100%
It's funny cause I could swear they suggest you change your oil more frequent if you drive
in dusty conditions?
Please do explain your therory of how the outside air doesnt get into the engine, be kind of hard for a 4 cycle combustion engine to run without air and fuel not being able to enter into the combustion chambers which in exchange goes into the cylinders![]()
