OEM Rear Set Disassembly?
InfiniteReality
I know the mount is already black, but while powdercoating rest of peg related stuff, I'd like to do them as well so they all match.
I've removed the bushing and had them done on the Gen2, but these don't want to budge. Tried a matching size socket and hammer with no luck.
Anyone have any ideas, without damaging?
Can you press the pins out?
I thought I could or at least get them to budge by trying to tap them out, but I couldn't get them to a little.
I did not test this, but the pins seem to be more of a composite material rather than metal this time around. I need to spend more time tinkering with it, surely I'll be able to get them out (hopefully without damage)
I think I answered my own question, had I done my due dilligence last night. Appears the rubber washers are separate from the pins, which appeared to me as all 1pc. Since they're separate, should be no problem to get them out one way or another.
If things aren't budging on a Hayabusa like the side stand bracket, I've learned to look on the backside just to make sure there's not a lock nut. In this case there isn't though.
Are you talking about the 3 bushings that the mounting bolts go through? If it is those, I have never removed them and the rubber they are made off has survived the oven when powder coating. I’ve had a couple of sets done with no issues.
For the life of me, I can not recall 100% if I removed them or not on the Gen2. I need to go dig through old pictures for kicks, I'd bet I have one of them before or directly after powdercoat.
