Oil change all done.
twotonevert
Member of P.E.A.
Got my oil changed. Thanks to Blancas fairing removal and a few tips I learned from Cap, it was a snap. Very easy to do. She is serviced and ready to run 2500 miles. I will go to a full synthetic on my next change.
Nice job. I have changed my oil and filter four times and have yet to remove the fairings. I did review Blanca's videos though, cos I know sooner or later I am going to have to remove them.
Once you have removed them the first time the tension leaves and you can do it no worries,done mine about 5 times now and get quicker each time:thumbsup:
tell me guys if i had a lil suzki oil in my bike about a quart mistakenly poured out and i put some honda oil in to replace what came out, it seems a lil thicker is it ok to mix the to?
Just make sure the weights are the same and you should be fine.
Now that I know where everything is at I think I could do it by just loosening the bottom. But it was nice to have it out of the way so I didnt have to fight it.
on a gen II? How in the world did u get the filter out without pulling the fairings? I desperately tried to do it once but couldn't fit my man-hands in there to get access to the filter. Would be much easier to change the oil without the whole fairing removal process. I have heard of a few separating the bottom of the fairings to gain access to the filter, but i still don't see how u could get it out
I have seen a tread where some one cut the hole in the fairing a little larger to fit your hand in but my search has failed to find it maybe some one else may remember this.
Can you post a link of this how to? I'm in the search for a service manual and get her ready. I've not posted in about.. 6 mo. Finally got my Gen II. '08.. not trying to thread jack. Need oil changed and PC.. will the V work on the '08?
Yes the PCV will work. I'm not for sure where to find the service manual though.
Sent from my iPhone using Tapatalk
James if we can get rid of the rain it shouldn't be to tough to get that mileage. :whistle:
Brandon I am so sick of rain. Especially with diesel being 4 bucks a gallon. :banghead:
