So "new shiny black" I'm guessing it's a gen 2. There is a tutorial on how to remove the fairings on this board, make sure you watch and follow exactly. It's intimidating at first but not hard once you get the hang of it. As you remove things make sure to pay attention to how they come apart. First, make sure you remove all of the push pins there is a small one at the top back of the wheel well that's easy to miss. Remove the bottom sail fairing first, then the large fairing. Be careful with the sail fairing because the plastic tabs are easy to break. Hardest part is getting the leading edge of the fairing to separate from the rest of the bike. Work from the bottom up once you get the bottom apart and you'll be fine. Also remember that one of the post/grommet attachments at the top does not pull straight out, you have to pop it out vertically. Once all the attachments are removed you grab the fairing and pull down and back to get it off.
Reinstallation is just the opposite of removal, work from the top down. Put a dab of silicone grease inside the grommets to facilitate install. I also put a drop of superglue on the outside of the grommets where they install into the ram air tubes to prevent pushing them through. When working on the leading edge just snap it over the ridge from top to bottom. Make sure all of the push pins are installed and you're golden. Once complete, give everything a onceover to make sure all is in the right place and meshes together correctly.
First time for me took about 2 hours because I was afraid to break something. Now I can remove the right fairing in under 5 minutes.
Another tip if you're worried about scratching is to be sure your fairings and hands are clean. There will be some grit in the nooks and crannies so wipe them down before installation also.
Be careful when reinstalling the drain plug, it's easy to strip the aluminum oil pan threads so torque it to spec. Use a new crush washer.
Removing the airbox to do spark plug replacement is also pretty easy.
