Tdog
I changed the oil and filter and according to the manual the Gen 2 holds 3.5 qts of oil with oil and filter change. When I added my oil the 3.5 qts put the oil even with the "F" in the sight glass. After starting the bike and letting it warm up to operating temp. to check for leaks, I turned it off and waited several minutes and now the oil level is just barely showing at the bottom of the glass. 3.5 qts is what the book say's should be in it and that's what's in there. Should I leave it alone or should I add more oil to get it back to the "F" mark?
