Remove the three allen bolts on upper portion of the fairing FIRST! Then run masking tape over an inch or so along the edge (where you just removed the three bolts from) of the nose fairing. You'll thank yourself later for doing it; prevents the removed fairing brackets from scratching your paint! If Suzuki ever redesigns the busa, I hope they leave enough room in that bottom fairing slit to remove the oil filter without having to remove the fairing....what a hassle. You don't need to remove any plastic on the GSX-R1000s to get at the oil filter.
