TXBusa05LE
"Folks - New and Improved Search is Online!!! Please give it a shot!"
Is the Mobil 1 15w50 spoken of in this thread a motorcycle specific oil or a regular automotive oil?Mobil 1 15w-50 with oem filter for the last 10k+ miles since adding the turbo.
GREAT QUESTION!!!!!!Is the Mobil 1 15w50 spoken of in this thread a motorcycle specific oil or a regular automotive oil?Mobil 1 15w-50 with oem filter for the last 10k+ miles since adding the turbo.
regular ol' oil that you can even pick up at walmart.GREAT QUESTION!!!!!!Is the Mobil 1 15w50 spoken of in this thread a motorcycle specific oil or a regular automotive oil?Mobil 1 15w-50 with oem filter for the last 10k+ miles since adding the turbo.
I'll change both every 1000 miles.
and the great oil debate rages on...Mobil 1 Racing 4T 10W-40 is designed for sport bikes. Most of these bikes have multi-cylinder/multi-valve engines and use a common sump, which means the engine oil lubricates the engine, transmission and wet clutch. So unlike Mobil 1 for cars, Mobil 1 Racing 4T 10W-40 has no friction modifiers, which could lead to clutch slippage.
The motorcycle oil also has more phosphorus/zinc for enhanced wear protection at high engine speeds and high loads.
In addition, Mobil 1 Racing 4T 10W-40 has a high performance dispersant/detergent technology for better high-temperature performance and engine cleanliness. Mobil 1 Racing 4T 10W-40 is also offered in a different viscosity grade than Mobil 1 for passenger cars. (Updated December 2007)
Tommy, Sorry I didn't see your post until today. I double checked our Wal Mart here in Victoria Tx, it's a 5qt jug of Mobil 1 red cap 15w50. Heluva deal considering my busa with turbo holds a little over 3.5 quarts.Hey 2time
I looked at our wally and ours is 4qt jug for 22+, are u shure yours is 5 qt? If so I'll talk to them. Where is the one you go to if you dont mind saying?
Thanks TC
The original topic is , what oil for a +450 hp 2008 Turbocharged Hayabusa .AM -->boosted @ Jan. 14 2008 said:1274554[/ATTACH] AM]
A rather huge waste of time/money, however, it's your bike to maintain as you please.
However, today's modern oils are so good, there is little need from a maintenance perspective to have such an abbreviated change interval for a street-only machine.
Though I understand there may be other driving factors involved, such as emotion, obsession, etc.
Warchild you obviously have no knowledge on turbo damage to oil. Most of the info you provide this board is good stuff. Stay off the turbo section until your knowledge is a little bettor in this area. Obsessive, maybe but when I have $30k in my bike a little "emotional obsession" is justified. Just for your own knowledge most turbo system builders suggest oil changes at the track every 2-5 passes. On the street as mine will be driven every 200-400 miles.AM -->boosted @ Jan. 14 2008 said:1274578[/ATTACH] AM]
+ 10000Warchild you obviously have no knowledge on turbo damage to oil. Most of the info you provide this board is good stuff. Stay off the turbo section until your knowledge is a little bettor in this area. Obsessive, maybe but when I have $30k in my bike a little "emotional obsession" is justified. Just for your own knowledge most turbo system builders suggest oil changes at the track every 2-5 passes. On the street as mine will be driven every 200-400 miles.AM -->boosted @ Jan. 14 2008 said:1277493[/ATTACH] AM]
