I think there are more benefits than just that Gixxer, and your missing the point of this stuff.
The bike fan is set to come on at a predetermined range on the bike, so it's a moot point where the boiling point is. Your cooling system is still going to maintain its current operating temp.
One good thing I can see about this stuff is that if the bike does overheat, it won't blow it's load all over the street because it wont boil over until almost 370 degrees (187 C).
The kicker about this stuff, IMHO, is that it is a lifetime coolant, requires no mixing, contains no abrasives, and requires no coolant system pressure. There is no water in the stuff, therfore there will be no vapor in the system making the coolant have constant contact with the metal in the water jackets of the motor. It's more efficient thats all.
As far as the other poster in the boards that claimed "a friend" using it got 38 degree's higher temps with the evans...sounds like he didn't burp the system and has air in it somewhere.
If you want a better opinion of this stuff, ask Don Smith on these boards.
A bitchin' pic' of his bike is here:
http://www.evanscooling.com/main27.htm
