COLDSTONE1298
I'm not a 19 year old squid and so these gizmo's are really nothing more then the possibility of causing a breakdown on a long trip if they're left active. Last year I had problems with the busa (2000 year model) not wanting to kick on the starter after the key is turned on and sidestand is up/clutch lever in. Pazzo levers were on and if i had it in a certain number position this would happen. If in the other it wouldn't. Either way it's either the clutch or sidestand safety switches and rather then replace and/or check on things I don't even use I'd rather have them gone. Heard enough stories of the tip over switch kickin on and leaving busa riders alongside the road that I want that overridden too. May go with a wrist tether setup instead.
So rather then rip them out, I heard it's better to use resistors or jumper wires so the ECU still thinks everything is working alright. Is this something I can find at radio shack or car shop? If anyone here has done this, what did you use? I will be putting on a Pwr cmmdr III USB for my akro single side exhaust this year. Wanted to mention that incase there could be any conflicts between it and safety switch overrides. Any advice is appreciated. Thanks!
