Pc3 problems
mrninja9
Banned
i was under the pass seat and fired the bike and the led bar on the pc3 while idleing goes haywire bike runs ok. i adjusted my idle up to 1000rpm so i didnt know if that did it or not
Your idle should be set aound the 1200 RPM area. I think the manual says 1150 or sometning like that.
hmmm.... Let me check mine real quick.
I'm thinking the regular PC3 isn't a wideband A/F display (the LED's) so it's a VERY exaggerated movement on the display.
The regular PC3 led displays the throttle position. Plug your PC3 in while still on the bike and recalibrate the throttle position sensor on you PC3 with the software and it should fix it.
<!--EDIT|bigjohn141
Reason for Edit: "cant spell"|1152492579 -->
