I believe everyone here knows I have kept my Busa bone stock. My main reason for that is because I don’t ever intend selling it and wish to preserve the original, exactly as Suzuki sent it to the showroom. It will probably end up as a collector’s item during my time here on earth and if not hopefully once I am gone someone will appreciate that and keep it as a collector’s item.
So let’s talk about gas consumption:
I recently posted a ride at 50mpg doing a long ride but with a number of short sprints some up to 160mph, I got challenged by a fella saying that is BS. Another poster mentioned that he had the same mpg before a pipe and a tune, but then it went down to 40mpg.
The calling BS fella recently did a long trip on a Honda CBX 1000 and was posting that he averaged 24mpg. First, anyone with a reasonable automotive background would know that is terrible. A 1,000 cc motor averaging 15 - 20kw of of power use during a normal ride, (a small portion of maximum) burning that amount of gas is about as inefficient as it gets. If we do a bit of research, some of those bikes got up to 40mpg back in the day, which is still not much to brag about. Were it me, I would probably use. CO data logger and first move the carb needle circlips up, after rebuilding them. Or look at jetting. Suffice it to say, I would be embarrassed to post those numbers.
Gasoline has an energy content of 33,526 kJ per liter.
A good design ICE has around 40% thermal efficiency today, some these days have achieved 50%.
The rest goes into wasted heat from the exhaust and the cooling system, as well as unburnt fuel out of the exhaust. So looking at that little Honda motor (I can attempt to calculate this but let’s guess) its thermal efficiency will be below 10%. Where does that energy go? It can’t possibly be heat from the motor, as it will glow red at that rate. Most of it will be unburnt fuel going out the exhaust. What does that do? Two things, it fouls up the motor, making things even worse, as well as washing a whole lot of oil off the cylinder walls, with a major reduction in engine life.
Reading all the posts here on the forum, I have always noticed that modified Hayabusa's have poor gas consumption and that this myth is accepted in lieu of increased performance. Automotive design and manufacturing was once my life as an employee with a prestigious German manufacturer and later as an aftermarket guy for mostly European sports cars. I can tell you for sure, it should be the other way around. If you don't believe me, below is a link, perhaps you will believe someone else.
Take the simple example of a pipe and a tune. First, the cats are gone, so there is a whole lot of heat coming out of the energy from your gasoline which is no longer lost. Second, you have better flow through the motor, less restriction, so the motor should be more efficient. It follows that for the same riding conditions maintained before and after your tune, you should have improved fuel consumption.
I think most here don't appreciate the effort that goes into factory ecu programming and cam design focussing on valve lead and lag and what it takes to get that perfect in the factory, when it comes to high performance motors. As simple as a factory exhaust change to a different pipe throws all that out the window, as the flow is now totally different.
Anyways, in short, when I did this as a living, if I increased performance with a decrease in efficiency (More gas for normal use similar output or at the same MPH), my boss would have sent me back to the drawing board.
Again, if you don't believe me, here is a link and if you google I am sure you will find a lot more from folks who are into this professionally.
