pictures , video, of Smoke LED Tail Light from d2moto ebay
Ikillbugsfast
this brake light did not come with any instructions so here is some pictures of my in stall it comes with the connector
wires from bike white/ black strip=brake light black/white strip = ground soild gray=parking light
wires from the brake light white=parking light red=brake black=ground
Suzuki Hayabusa GSXR1300 Smoke LED Tail Light.MPG - YouTube[/url]
Is the taillight bright when you hit the break? I checked your video, but can't really say.
Thanks 4 the help
it all so have blinkers in it too. I was thinking about making them brake or parking lights just to add more lighting but I am still working one that one ? I am going to use the stock blinkers here is a there vidoe
2008-2011 Suzuki Hayabusa LED tail light - YouTube[/url]
I've got the same light and love the look of the integrated turn signals on the +4 tail
well I just placed the order from their website last night.
did u remove the whole tail to install the tail light?
all I did was remove the license plate bracket ,took out 4 push pins from under the bike.got a screwdriver and work the trunk bottom out from under the tail plastic then pushed the bottom of the trunk down .then removed the back of the tail light bracket 4 allen bolts.then pulled the light through the trunk.if you need I can try and get some pictures
That will b awesome if you can take some xtra pics.
Thanks
this is how I did it ,bolts under tail to license plate are 10 mm take them out .then take out push pins by pushing middle dot in then pick out with something then get a screw driver in pry the trunk out from under the trim both sides then push down the trunk bottom then there is 4 screws and two bracket 4 allen bolt 4mm on the side of bracket then remove brackets then pull brake light though truck then restall
Bro,
Thanks 4 the pics, piece of cake to install.It only took my 30min, looks awesome (i did the clear lens tail):thumbsup:
I had changed the sockets in my turns a while back to make them parking and turns. With this tail light I used the turns and made my others parking asnd brake. The turns are not that great, but I love having more brake light.
