Pit Bull stands with swingarm extension
1slowbusa
Hi,
I am fairly new to the thread. I bought the front and rear pitbull stands for my 2003 busa and turned around and put a 6 inch swing arm extension on the rear. Now the rear stand will not reach the spools. I dont see anywere to remount the spools so i thought about getting some pipe and cutting the stand and welding some of the pipe in to make the stand taller.
Does anyone have any recommendations?
Go to T-Rex_racing.com and you can see how they stands are. That's where i bought mine from and I have a 7 inch stretch. It looks like the stands you have will work (the back on in the picture) just turn the top piece around so that the red piece is facing in instead of out. That what the bottom of your swing arm catches on to cause you're right you can no longer use spools. Let me know if this helps
