I like to keep those secondary injectors scrubbedI use 6th anything above 35mph
man?Pull the motor and split the cases
Thankyouthe 6th gear is crap
also the gear at its rh - watch the dogs - as far as i can see they are also damaged .
load down/get the gen2 microfiches and you´ll understand what parts u´ll need .
Gnawed on by rats/mice lmao…
Make sure none of the cir clips moved!Any suggestions? I.e purchase separately the gears and shift fork required and rebuild meaning I have new and old gears on the shaft or a reconditioned whole deck, don't know which way to go with it.
Cheers.
Yes, this is the usual cause of the gear sliding too far over and getting munched.Make sure none of the cir clips moved!
Man ?man?
u know what immense work that occurs? i would say round 25 h for an very/full experianced mechanic
and all that possibly without the gen2 manual ? NO WAY !
follow @Kiwi Rider `s hint first .
and move the motorcycle immediately/first into a rain and dustproof garage.
the way she is now standing naked in an britsh (back)yard (the license plate of the Renault in the background suggests this to me), she will never survive this.
