Plug and Play progressive Nitrous control - nos/fuel/ignition control
smithabusa
Site Sponsor
Petrik has done it again, and made the gen 2 ecu even closer to a stand alone setup. Now ready for testing is a gear based progressive NOS setup that simply plugs into the PAIR connector, and will eliminate NOS in 1st gear if desired, and allow any duty cycle you request in each gear (keep in mind solenoid will dictate the lowest you can go etc).
Currently, to activate requires wide open throttle and hold the mode select UP button, more options are being considered for those who dont like holding buttons LOL.
Just a quick video showing different pulse settings in each gear. 6th gear was set to 100% (on all the time)
- Nos ecu gen 2 gear based[/url]
