And just as I posted that info, petrik released software with ramp times for each gear now turned on.
Moving up to next version leaving a more or less stable v2.1 to be as it is.
index
Name: Hayabusa ECUeditor for K2-K7, K8- and BKing models
Version: 2.2.0.6
This is the first Alpha (alfa) version which includes gear based rampup time setting. You can define a rampup time for each gear. During transition the previous gear value is used until the current gear rampup is reached. This is tested on desktop not on a bike. (One potential problem to watch is if the gear detects neutral between shifts when the rampup starts from zero. On desktop that does not happen, but obviously its possible with GPS sensor.)
All rampups (nitrous solenoid duty, fuel % add and ignition retard) happen currently at same rate having same starting point which is previous gear values for gears 2-6 and 0 for gear 1. The maximum is the value set for the gear at the end of the ramp time. There has been a request for fuel ramp up delay - but that is not (at least yet) implemented. Need to have some hard facts as dyno charts that this is really needed, particularly now with the ramp up time control. It can be implemented, but it is only one more parameter which can be misconfigured leading to problems.
More practical way, if you set
gear1: 50%duty and 2000ms time delay
gear2: 80%duty and 2000ms time delay
gear3: 100%dity and 4000ms time delay
the system will operate like this: Gear1, nitrous and fuel will ramp from 0 to 50% duty in 2000ms and stay there until a gear change. After gear change the rampup will tahe gear1 values as starting point and gradually ge to the target value 80% in 2000ms. This allows the bike to better hook up the nitrous power to the ground as the power delivery "delay" i.e. rampup can be set.
The reason why I am challenging the need for fuel delay is the following:
- At 8000rpm the engine takes in around 192Litres per second
- Assuming that the airbox and intake volume is 5litres before fuel injector it takes around 26ms to to completely empty the airbox, i.e. max 3 fuel injector cycles when engine may run a bit richer.
(Above assuming I had my maths right)
I see this problem and need for fuel delay settings for engines where you have a very high hit without a rampup.
