Popping when decel
AaronG
I know it is doing this because of the pipes but what can I do to fix it and what is actually happening.  It only backfires when letting off at high rpm's.  Thanks.
<!--EDIT|AaronG
Reason for Edit: None given...|1144640447 -->
You are running lean. It will backfire if you have an intake or exhaust leak too. Have you done the PAR blockoff yet?
Do a search for ...PAIR valve..or marble mod...
Take off the PAIR valve or do the marble mod.
The PAIR valve adds oxygen to the exhaust for cleaner emissions. When you mod the pipes, the PAIR valve causes backfires.
Thanks guys. I knew I could jump on here, go to bed, and have an answer in the morning. I will fix it up tonight.
