ToXSicK RoCKeT
I will correct the rest later.
Any Comments?
members.cox.net images missing
Well looks like a good plan And i think you know already, but your wiring diagram is inaccurate ??? But as long as you know how to "properly" wire thoses relay's, you should be ok
FYI.....On a STANDARD 5 Pole bosh relay; 85 & 86 is the "coil side" of your relay. 87A is your Norm "CLOSED" pole. 87 is your norm "OPEN" pole. and 30 is your "COMMEN" pole.
Relay's can be used and wired in many different combinations though. If you neen anyhelp on wiring your system PM me or give me a ring
Phil 1-209-247-2778
