problem with clutch hub/basket, need help
02bluebusa
So I made a tool to hold the inner clutch basket in place but as I try to get the nut loose the outer basket is turning.... any clue or help as how to get the clutch hub nut off?? Is it normal for the outer to turn and be this hard to get off? They make it look so easy on YouTube.... :/ Thanks
The reason the outer is turning is because the tool I made has a handle and it rest in the outer basket groove or whatever you call it
