Problem with sewer - Need advice
see man i told you hahahah they didnt always instal gravel. What i would do is expose the pipe. see what material it is should be a corrigated pvc type. get a smal section of it and cut a slit down one side so you can open it up. and hose clamp the hell out of it... Put you some gravel in over it then dirt. i would go with maybe 3 inches. so it can rin still dont compact to much. then your dirt... do not use this as a location can complicate things later down the road and update your drawing that you have put in in a fire proof safe along with other documents... will come in handy later down the road.... if you need more advice you knwo where to fing me:whistle:
How can I expose the pipe if it keeps filling with poop water? Thanks for the advice!
Odds are that it wouldn't really hurt anything to just dump some gravel and quikrete into the hole to seal it.. If it is the field side, you are already draining sewage into the substrate. Use the KISS concept to carry out the repair.. If the pipe is just nicked you should be okay with some quikset, voila no more leak..
I bought some long sleeve heavy duty rubber gloves; gonna feel around in there and see if I can feel how big a hole I cut.
