The past week have had about 3 different guys on the dyno using the new nitrous harness. I have made a small change to it for activation now but think these are ready to be sold
Two ways to turn Nitrous On:
Option 1: Push and Hold Mode UP Button Entire Time You Want To Spray / Window RPM / Wide Open Throttle
Option 2: Have Toggle Switch in the On Position / Window RPM / Wide Open Throttle
Petrik's ECU Editor will allow the following, for Each Gear!
- Adjustable % Duty Cycle (want no nitrous in 1st gear, no problem, want 50% duty cycle, no problem)
- Adjustable Fuel Add %
- Adjustable Ignition Retard Amount
- Adjustable Fuel delay (have your NOS Solenoid in the tail section, and want to delay the fuel a little so you don't go instantly rich while the line builds with nitrous, no problem)
- Adjustable Solenoid Frequency (gives the ability to tune your progressive in addition to duty cycle)
- And soon to be worked on is ramp times for each gear to make it that much smoother transition for you large nitrous shot guys.
Now if you just want traditional 100% nitrous when you push the button or reach the set criteria with toggle switch on, no problem either, just set your duty cycle to 100% for every gear you want it in.
