Lyle,
Sorry that it took me so long to get back with you, but I just returned from Del Mar, CA.
The manufacturers test will run tests at speed on the road. By connecting
a manometer (pressure sensor) to the air box, they can track what kind of
pressure is experienced at a given speed. This can be fairly simply
replicated on the dyno with the use of a smac-pac electric motor controller
and a large fan. They simply ramp the fans up to produce the same air box
pressure as recorded on the road. By building this "map" of fan power =
air box pressure, they can then have an input to the motor controller that
simply references the speed of the rear wheel. This setup is quite
expensive, so virtually no shops would pay for anything like that.
Dynojet looks at ram air a different way. Since the manufacturers have
already compensated for the additional fuel needed when the air box is
pressurized, we need not reinvent the wheel. This means that since their
system is self-compensating, we don't have to compensate any more. Since
the pressure in the air box is static on the dyno, the jetting is also
static as far as compensation goes. We don't need to put in larger main
jets, or more fuel on the dyno to compensate for what will happen on the
street at speed, since the bike already compensates. Whatever happens on
the dyno translates to what will happen on the street. The carburated
bikes use float bowl vent tubes to pressurize the float bowl while the fuel
injected bikes (like the 'busa) use the air box pressure sensor to increase
fuel at speed.
While the horsepower will go up slightly on the street at speed with the
extra pressure and fuel, it's not really a large difference*. For these
reasons, we do not try to replicate it on the dyno. Since all the bikes
are tested in the same static scenario, all things are equal. That means
if one bike makes 5hp more on the dyno, then it will make 5hp more on the
street, even at speed, since ram air is power on top of the normally
aspirated power.
*One of the magazines tested a ZX-9R some years back. They found no air
box pressure until over 100mph, and the pressure at 160mph would equate to
around 6rwhp.
