Hi guys
My B King is getting nearer to completion it has had a major rebuild and makeover.
It now wears a full Yoshimura r55 exhaust system, I intend modifying the air box to have cold intake pipes and will be fitting a hi flow Piper Cross air filter.
I intend having the ECU re flashed and having the set valve disabled at the same time.
Does any one have a nice map/bin file that will work with my set up ?
My other question is why is the oxygen sensor always disabled in tuning situations.
? As I understand the sensor regulates the fuel mixture dependent on the reading it's given ? Surly this would make the motor use more fuel?
Or is the standard sensor not up to the job is this where wide band sensors com in ?
Thanks in advance for advice
Regards Neil
Regards Neil
