Rear brake adjustment
WACKEM1
Anyone know if there is a brake light adjusment needed if rear brake pedal os adjusted down? Recently installed lower pegs an adjusted brake pedal lower! Went to install a brake mod today an noticed brake light is steady lit even when brake is let go! Any help would b awesome!
Brake light switch needs adjusted..i guess when u adjusted the brake lever down its holding that brake light switch down also not letting the brake light go off..im not really sure how to adjust it but i know its attached with springs to the brake lever..
Ill look im the manual and report back..
