manatrader
Where is the rear tire mount bolt sitting at?
I wouldn't ride it tell you find out whats going on, could be too risky.
whats that?.. the big six sided nut?Where is the rear tire mount bolt sitting at?
yes.. 3 on both sides..Where does the rear nut sit on both sides count the lines from the end of the swingarm inward, the lines you use to adjust the tire are they in the same spot?
yes the nuts are tight.. i assume you mean the front one and the rear one on the same short screw..The small nuts on the adjust are both locked down too?
what do you mean?Also since you have it on a stand any movement from side to side on the tire? Keep in mind a small fraction under 100 pounds of torque will move.
Don't shove, just try to see if there is any movement.what do you mean?Also since you have it on a stand any movement from side to side on the tire? Keep in mind a small fraction under 100 pounds of torque will move.
should i try to shove the tire back and forth perpendicular to the bike and see if there is any movement?
It fell because the cush drive is worn! I still think you have an alignment problem coupled with a worn chain/cush drive! Do a string alignment check on the tires.... Set the chain sag and IF they check fine then do what Rev said by putting the bike on a stand and rotate the tires to see if they wobble. In the pictures it looks as though your rear sprocket is worn and leaning to one side of the chain... Not a good sign.another thought.. you know when you take your rear wheel off... that sprocket housing thingie just feel before.. is that normal.. wonder if something get damaged when it hit the floor.. or something got lost?
this housing unit is part #13 on revlis diagram..
you guys know what i am taking about.. i feel to the ground .. about a 2 feet drop.. on to the cement floor.
thanks everyone.
Ohh, good point, Occum's razor and shid... Simple...Just a question....but on either of those low speed drops, did the tire continue spinning?....causing the damage you see?
Very good question, could it be that simple?Ohh, good point, Occum's razor and shid... Simple...Just a question....but on either of those low speed drops, did the tire continue spinning?....causing the damage you see?
over tightening the rear axle nut?A 4mm hex is what takes the side panels off and he said that it's hitting the chain links. 3 to 3½mm of clearance aint much.
A 4mm fits in my bike with plenty of room to spare. In fact the next size up (5mm you use to remove the seat) fits between the tire ridge and chain on my bike.
Something has got to be out of whack.
Maybe I'm missing something here, but how can worn cush rubbers cause lateral play? There's a bearing in the sprocket mounting drum so the sprocket can NOT go side-to-side. Of course if the bearing is shot, the force of the chain pulling on it can throw things out of alignment.
I don't think this is one to play around with...time to take it to a good bike mechanic.
