Well now that I look back, Blanca talked about removing the larger rings but he didn't mention a thing about cutting the small retainers on the bracket itself. I bet that's what he did though. So it's not a 100% reversible mod...unless you buy a new rectifier and it comes with the retainers we're taking about. I'd probably get a Mosfet rectifier if I did replace and/or relocate it.Blanca mentioned unfastening the clamps (2) that secure the regulator/rectifier wire to the bracket but he didn't say how they open.
I just spent the last few hours looking at cable mounts. I don't think it matters much if you get ones with the arrow head pointer, the christmas tree rings or the barbs. It looks like a pretty small hole so barbs might be easiest to use without needing to do any reduction with sandpaper. I'll bet that hole is about 1/8" and every cable mount I looked at was designed for a 1/4" hole or slightly smaller. No biggy, sand it down if it won't go in. If it doesn't have a release, cut it off when necessary. The pin will fall out of the end of the tube if you take the bracket off.There's also heaps on ebay too although not the Xmas type.
I sprayed with truck bed liner and baked them in the oven for a couple hours...that was a few years ago and they look just like the day I did themBlancabusaless hasn't been here in a while, but yes, the pegs are powdercoated black.
Some of the later model gen2 passenger pegs were factory black.
I also band-sawed and filed the hooks off of my gen2 passenger pegs before powdercoat, and you couldn't tell they were ever there.
Cool thread bros
Man I miss moddin my bus…
I wish I could find her again and see what condition she’s in. I spent a lot of time on the little things to make it mine.
