Redline stands.
Pinky Winky
I just received my Redline stands and went to try them out and the front stand when I place it under the forks only one side is touching the forks so the bike wants to fall over. Is this normal and what do I need to do to correct it?
Never use the front alone. Wait till you get your spools my friend.
Once on the rear, the front will line up just fine.
I had same problem - apparently I didn't read the email carefully enough first. Almost fell on my car.
+trillions and trillions!!!
rear stand first, then add front stand. could've been super costly.
Call them up, maybe they will work with you!!. I ordered BW's stands last year and had no problems. They were very helpful.
Very good advice; I have a pair of PitPosse stands which work quite well and they have a special if you buy the pair as a set.
