Removing Bushing from Passenger Footpeg
BigBSBusa
What's the easiest way to remove that bushing from the passenger footpeg? I know it's pretty simple, but I can't get that sucker out of there.
Isnt there a c-clip holding it . I'll go check for ya, Ken, hold on.
Its a c-clip ! Just push it off from around the rod going through the center of the footpeg connecting it to the rear support hanger.
'Preciate it but that's not the piece I'm talking about, bro! The rubber bushing/gasket that the exhausts connects to.
Would it work to tap it through with a deepwell socket?
Maybe I'm not strong enough, but it wouldn't come out for me.
Oh yeah, now I remember. It does get pushed out!
When I had them chromed I had to push them out before I sent them off to get chromed.
Try spraying or applying something like a liquid between the rubber and the metal piece holding the rubber bushing to help slip it out.
Spraying something like compressed air or something liquid?
Put some azz into it big guy, dayyumm !
Silcone or somthing slippery. I now if my lil azz can do it, your big burley azz shouldnt have a problem.
If I remember, I also used a screwdriver too.
BigBSBusa
Just Another 'Busa Lover!
Group: Donating Member
Avg posts/day:13.78
Location: Fightin' the War on Terror Posted: Oct. 23 2005,22:16
Okay, I got it. Technique over strength, playa! [/QUOTE]
So, how did you get it out, Einestein ?
Not 1 screwdriver, but 2 to get set things in motion and then it pulled right through.
