lankeeyankee
Banned
(GENII)
The last oil change went over my 2300 mile limit, so I decided I wanted to remove all the oil I possibly could.
I always remove the 2 allen head bolts that hold the oil cooler line onto the engine block to make it easier to remove the filter. Well this time I blew about 15PSI of air pressure into the line causing oil to come out the engine block. When I refilled my crankecase without doing this it holds around 3.75 qaurts to put the oil in the middle on the site glass. This time it took every bit of the 4 qaurts to acheive the same fill level.
Anyone else remove the old oil from the cooler when changing the oil
Hint: If you are going to do this also on your next oil change be sure not to exceed 15 PSI of air pressure when blowing the line and use some type of deflector to direct the oil into the drain pan to prevent oil spraying out on you when most of the oil has been removed, dont ask me why just trust me.
