OK, fork newb here, so go easy on the flames...
I replaced my fork seals the other day, using CAT3's tutorial, and when I took it out for a test ride, the forks felt way too soft. I loosened the cap bolt preload & rebound adjusters according to the manual, and reset them to their previous settings after reassembling the forks. What is the stock oil weight, as the old stuff I poured out was the color & consistency of honey, and the new 7wt I put in seemed a bit thinner. Do I need to pull the forks again & put a heavier weight in?
