Replacing those awful front and rear foot pegs
Here you go:
Rear brake sensor adjust
I'm not sure if the rear pegs can be used on the front, but I actually like the stock pegs and I like them even better in black. I may offer to buy them from you...
Adjusting the shift lever is easy as all you are doing is lengthening the push rod. The two things you want to watch out for are a) the connecting bracket to the transmission rod ( or whatever it's properly called) likes to be at 90°, so you may want to loosen it, pull it off, and then put it back on one tooth adjusted. The other is that lowering that shifter may make it hit the kickstand, and unlike the upper gears pushing the lever down into first requires a fair bit of movement range. But you should be able to lower it a little.
