kamikazi89
Guys i need help with s2000 injectors setup on a stage 1 turbo gen 1 busa with power commander v.What is better to do as i have the option of the 4:1 fmu and other option is 1:1 fpr with map sensor connected to pcv.Also base fuel pressure for each setup injectors compensation in the ecu?Thanks in advance
