Please someone correct me if i am wrong but S2000 can supply 380 cc min and 400 or more witth the screen filter removed (you must use an external fuel filter something that i consider an upgrade) which equals 1520cc per minute.
Using 5.5 cc per horsepower then 1520/55= 276 x 90%duty = 248 hp
I am GUESSING that with an 1:1 regulator and s2000 injectors you can reach easily 250hp if you increase the nominal fuel pressure from 43 to 50 psi.
The main problem is the idle fueling and i don't know if the 1000 or even 600cc injectors can provide good idling.
